speedometer sensor routing - 1988 244dl
my question: where is the wiring for the sensor supposed to pass through the body to reach the sensor at the rear axle? a previous owner or mechanic has the wiring sharing the hole with the in-tank fuel pump access cover, which seems incorrect.
i ask because i have the in-tank pump removed (it wasn't working, even with the #4 fuse pulled and a jumper wire connected from #6 to the righthand side of the #4 fuse terminal, awaiting a tank gasket [the one on it was already junk before i removed the sending unit assembly, so i was pulling it even if the pump worked]. it also wasn't working when 12v applied directly to the connector (and ground) from a charged 12v battery. however, after getting it out fully intact (including the sock and the float ball), and dismantling the simple electrical connections, i applied 12v to the prongs on the pump and it worked instantly, and subsequent testing now has it working with 12v applied to the harness connector/ground ring. probably minor oxidation issues, as the pump is fairly new (as is the tank itself).
thank you..
wally
thank you..
wally
Geigenbauer
04-18-2017 06:51 PM
EivlEvo
12-01-2015 09:36 AM
journeyforce
04-04-2013 04:55 AM
