Starting Problem
Old Aug 9, 2006 | 08:52 PM
Volvo240guy's Avatar
Default Starting Problem
Hey I posted a problem on this same thing well. I checked the relay fine changed the plugs wires cap..... and so on.. I did need a new Gas cap so I got one of those. I then thought it m ight be gas problem for a gas station Still same thing not as bad as be for. Could a starter do this it will crank and then shut off then I have to crank it again soem times and it starts right off. In the morning it starts right off. SO WHAT DO YOU ALL THINK !!!!!!!! Im so confused I dont know where to start now.... When it is running it runs great. I did not replace the relay I did a test that some one told me to use a tester and hold it on the fuse that works the fule pump when I turn the key tp start it the light should come on the tester that will let me know the relay is working... Now where to look. I have never had a problem until this week.....
Old Aug 9, 2006 | 09:04 PM
Default RE: Starting Problem
Speed sensor locate in the back of the engine.
Old Aug 9, 2006 | 09:15 PM
What does it do ?
Old Aug 9, 2006 | 09:53 PM
Where at on the back of the engine is the sensor? and is it close to the drain for the AC and cou;ld water cause it not to work right? How hard to replace?
Old Aug 10, 2006 | 12:15 AM
The Speed sensor tell the computer when to give spark and pulse the injectors.
It is located at the back top where the transmission meets the engine. Find it and inspect the sensor closely.
If the outside sheilding is coming off at all replace it.
No the A/C wouldn't even come close. The drain is under the car.
Old Aug 10, 2006 | 07:50 AM
Thank you for the email and the info I will check it and see if this is it.. Would it do it every now and then ?
Old Aug 10, 2006 | 11:56 AM
I checked the covering on the sensor and found that it was in really bad shape the black plastic is torn and just in really bad shape. I looks like the wires inside are in good shape but they probly are have a small cracks in them I was thinking if that was the case could the wire hit the block and maybe have some times shorted out the sensor some times... ?
Old Aug 10, 2006 | 08:50 PM
Yes that is exactly what happens.
Old Aug 10, 2006 | 10:52 PM
Hey thank you for your help and I also orderd a ECU and a new relay the other one had 1992 on it LOLOLOL< so that should do it.. DO you think that I should go ahead and change the ECU?
Old Aug 10, 2006 | 10:54 PM
NO on the ECU till you see if the speed sensor and relay fixed it.
Old Aug 12, 2006 | 02:11 AM
nadernur's Avatar
How much does this sensor cost!
Old Aug 12, 2006 | 10:32 AM
I think like $35.00 or so.
I don't really deal with the prices.
watchdog
Feb 9, 2014 01:41 PM
TedP
Feb 12, 2007 01:31 PM
br549
Sep 28, 2004 09:15 PM
watchdog
Jan 23, 2004 11:36 AM
