Station Wagon surges in idle and stalls in gear
Old Mar 3, 2011 | 01:37 PM
rtaylo's Avatar
Question Station Wagon surges in idle and stalls in gear
So here is the whole story,
It started with just stalling at lights. Then it would stall whenever it wanted, quite frequently.
I have replaced the fuel pump, fuel filter, air filter, mass airflow sensor, spark plugs, and alternator.
On a side note I have trace amounts of oil in my air intake.
The guys at the shop said it was the mass airflow sensor, and wanted to charge me over 500 bucks to fix it. I ordered the part myself for a little over 100, and changed it in 5 minutes. They also mentioned it had a weak signal coming from the ignition.
I just don't know if I can trust someone who wanted to charge that much for two screws and a bolt. Anyway I found myself at a dead end here.
My next theories are to replace spark plug wires, and the PVC valve, but this is just my shot in the dark approach.
Any ideas? it's a 1983 Volvo 245 GL it's before they put in the Diag computers...
Old Mar 3, 2011 | 06:16 PM
TIPSP's Avatar
Got Boost?
Might want to check if the TPS is working right.
Also check the Idle motor. maybe clean it out.
Wait for the experts to get on...
Old Mar 3, 2011 | 08:21 PM
swiftjustice44's Avatar
So...you purchased a brand new amm for $100? Do they have any more? I'll take 6. The reason they were asking $500 is a. it was a new/reman unit that has a warranty and b. they want to fix the problem the first time. Yes ,it is simple to swap out but if you truly did it in 5 minutes I'll bet the air box bracket did not get reattached...that takes 4 more minutes. The simplest test for an amm is to simply unplug it...the car should run...but appreciably worse...it's called the limp home mode. If running does not change and the running is crap whether connected or not, probably not the amm. With a manual, you can check the volts at the amm to see if it's in specs. Sounds to me it's idling too low...have you tried idling the speed up at the throttle body? It's the big black knurled ****...also may have a vac leak...
Old Mar 3, 2011 | 10:56 PM
rtaylo's Avatar
I have tried to adjust the idling speed, however it doesn't seem to change at all when i turn it. Is it possible that the idler has gone out?
I have checked all of my hoses for a vacuum leak using a spray bottle filled with soap and water.
I was wondering if whatever is causing this issue could be related to the oil that seems to be making it's way into the air intake.
On a side note, the Mass Airflow Censor set me back about 130, but I did get 45 for bringing in my old one.
When I do disconnect my mass airflow censor the engine will really surge even worse. I placed my hand near the air intake and it appears that it is almost gasping for air.
Old Mar 3, 2011 | 11:34 PM
Titan Joe's Avatar
I don't think that there is a PCV valve, but there may be a flame trap in the PCV system. I would clean that, the throttle body and the idle air control valve like TIPSP suggested. I'm not sure if this year of car has one, but I would think it does.
Old Mar 4, 2011 | 12:03 AM
having just dealt with fuel pump and pressure issues, I'd suggest having someone check the fuel pressure and fuel flow. erratic fuel pressure from a bad regulator can make all kinda funky drivability issues, often erratic.
rgreen4
1998-2000 model year V70
Jul 15, 2012 11:43 AM
Kenwood
Apr 18, 2011 11:04 AM
91shelby
Aug 3, 2010 07:55 AM
caltemcarrs
Nov 28, 2009 07:18 AM
Qamar
Aug 20, 2006 02:54 PM
