steering wheel removal info plz
Old Feb 29, 2012 | 06:04 AM
scorpius's Avatar
Unhappy steering wheel removal info plz
got a new signal/high beam lever switch i would like to install, but dont want to take the chance of the airbag blowin up in my face. whats the protocol on removing the steering wheel? got a 91 740....
Old Feb 29, 2012 | 11:05 AM
swiftjustice44's Avatar
Ain't gonna happen Skippy! Seriously, if you have any concerns whatsoever, just disconnect the battery.
Here's your wheel (this one's off a 91 740 also)...
There are two torx screws on the back side...see the holes?
After you remove the bolts, the air bag is loose. The bottom edge tucks under a lip on the wheel so tip it out from the top and lift out. It honestly takes less than 5 minutes once you getthe correct torx bit.
Here's the backside of the air bag. The clock spring is self-contained so it is a piece of cake.
nortons
Feb 22, 2015 11:14 PM
nicolaselias
Mar 24, 2011 08:48 PM
RDP3430
Mar 18, 2011 04:56 PM
mrberl
Sep 8, 2010 12:48 PM
billy78
Jun 24, 2005 09:58 AM
