Stuttering problem in my 87 244...help?
Alright so i will try to expain as simply as i can. first off this stuttering happens hot or cold day or night. its almost like i have a fuel injector just randomly shutting off, and i can never make it stutter it just does it when it wants to. It never does it under full throttle and seems to do it more at cruse, or when your not on the gas but not off it (if that makes sense, its that in-between area). I have checked plugs and they are fine...and new ones are in it now, the wires are fine, the cap and rotor are fine. About 6 weeks ago I pulled the injectors and tested the spray on them...they sucked but this stuttering problem just happend so altho the injectors may be all retarded i dont think they have much of a factor on this. Im thinking it could be a faulty ICU or maybe ECU? any ideas would be great since im stumped. thanks!!
Check fuel pressure regulator, pull vac line and look for fuel, check for vacuum from throttle body.
when you come off the gas the regulator should direct excess fuel to the return pipe.
If its failing then the injectors are getting too much pressure, they keep firing anyway regardless of the throttle position. The sprak plugs keep sparking when your foot comes off the throttle and the fuel pump keeps delivering fuel, so something has to control the fuel delivery/pressure.
