Tall tires and small lift
Old Jul 10, 2019 | 12:11 AM
Chris Blickfeldt's Avatar
Default Tall tires and small lift
What is the tallest tires I can run on 15 Inch stock I'm turning my 93 940 into a rally runner
Old Jul 10, 2019 | 01:29 AM
/anything/ taller than the stock size will make the steering heavy and wooden unless you can also mess with the alignment appropriately. and I'm pretty sure you'll bottom out and scrape things unless you can use taller/stiffer springs too, along with suitable shocks.
lift the back more than an inch or two, and you'll need to mess with the length of the thrust bars that tie the differential to the rear subframe, and likely the drive axle length too, and the panhard rod.
I saw a 940 wagon once that was sitting on a chopped 4x4 truck chassis+frame, it had *big* tires.
Old Jul 10, 2019 | 01:31 AM
crazy russkies
johnwartr
Sep 12, 2013 10:01 PM
tbass
Dec 29, 2011 09:00 AM
Platinum52
Dec 15, 2008 08:22 AM
ottis
Jun 4, 2007 11:29 AM
kwik850
Mar 24, 2007 12:57 PM
