In tank fuel pump?
Old May 9, 2014 | 03:33 PM
don carlos's Avatar
Default In tank fuel pump?
Hey guys, I just got my 240 back from my mechanic with a new fuel pressure regulator. It died on me a month ago and he got it working again. In the process though i replaced my fuel filter, coil cap and rotor, fuses, mass air flow sensor and a couple hoses. Now it runs solid! The issue is that I now have a loud humming that comes from my pump or at least it sounds like its coming from there. The faster I go the louder it hums. Is it over working because my in tank filter is bad? or did I just do something wrong when I put on the fuel filter? I don't think there should be any issues with that since it was pretty straight forward but I just want to be sure. I wanna fix the problem before it gets worse. Any help is welcomed! thanks
Old May 9, 2014 | 03:34 PM
don carlos's Avatar
Its a 92 fyi
Old May 12, 2014 | 06:46 AM
act1292's Avatar
A noisy main fuel pump is the first indication that your in-tank pump has died and needs replacement. Here is a nice writeup on how to diagnose and replace the in-tank pump:
In the Tank - 240 Volvo Tank Pump and Sender
Old May 12, 2014 | 09:27 AM
240-FAN's Avatar
When you do get around to changing the in- tank pump, replace the o-ring on the sending unit.
Also, try get a Bosch or airtex unit. They are only slightly more expensive than than Chinese ones from eBay but are wired correctly and will last longer.
Old May 12, 2014 | 10:22 AM
lev's Avatar
lev
Well, "faster you go, louder it sounds"? No, that doesn't sound like a pump, more like a bearing. Failing pump usually fails under high demand for fuel, under heavy acceleration, etc. if it doesn't just quit. Noise, sure, it's a motor--if it gets too loud obviously it's out of whack. But may be wait to be sure, don't just throw parts and $ on the problem...
rphud
Sep 27, 2014 06:06 PM
spidersilva
Aug 17, 2011 07:23 PM
AnEskimo
Oct 7, 2010 07:28 AM
skyrider20
Nov 29, 2008 07:01 PM
