in tank fuel pump removal
Old Aug 1, 2006 | 04:09 PM
pirate240's Avatar
Default in tank fuel pump removal
what kind of tool do I need to pull the in tank fuel pump out of my 84 240, and were could I find it?
Old Aug 1, 2006 | 07:47 PM
wojeepster's Avatar
Default RE: in tank fuel pump removal
DISCONNECT BATTERY, lift up carpet in trunk, undo screw(s) to cover plate. The bung removal tool is available from ipdusa.com or you can carefully loosen the bung nut with a punch and tap it the way it loosens (I think counterclockwise) be CAREFUL when you are moving the assembly about in trying to remove it from the tank it is possible to break off the inner wires and then you have to buy new sending unit (105$) fpcgroton.com ask me how I know. I made a bung tool by welding a couple pieces of steel to an old socket. If you choose to do this do not weld within 1 mile of your gas tank or you will be 'hoist by your own petard' and killed. Getting the intank prepump out of the tank is not really fun. I do not like working around fire starter. Put your careful hat on.
Old Aug 2, 2006 | 11:21 AM
cbevis's Avatar
lol at "careful hat"
rphud
Sep 27, 2014 06:06 PM
spidersilva
Aug 17, 2011 07:23 PM
AnEskimo
Oct 7, 2010 07:28 AM
skyrider20
Nov 29, 2008 07:01 PM
