temp gauge repair question
Old Mar 1, 2007 | 09:37 PM
montysano's Avatar
Default temp gauge repair question
Hello all,
I'm getting ready to try to diagnose the problem with the temp gauge on my '90 245. I know that the standard test for the gauge is to unplug the wire from the sensor, ground it, and see if the gauge goes all the way up. However, if the compensator is faulty, will this test still work?
If that test will not work, should my next move be to bypass the compensator with a jumper?
thanks,
monty
Old Mar 1, 2007 | 10:46 PM
JetTech's Avatar
Default RE: temp gauge repair question
Hi Monty,
If you remove the wire going to the sensor, have someone in the car watch the gauge while you tap it on the block. Don't hold it there just tap it, the gauge should jump up. My original temp. comp. board didn't work but I was able to get one from another cluster that works fine. It might be cheaper to buy a whole cluster off ebay with a known working temp. gauge then buy a new board. At least that's what I ended up doing. Just a thought.....
Old Mar 1, 2007 | 10:52 PM
I would start with the jumper. 95% of the cars out there are already jumped.
Big common problem with them.
cc sbrider
Sep 27, 2014 03:16 AM
AnEskimo
Mar 7, 2014 08:29 PM
blackbrick
May 7, 2011 01:46 PM
vcolper
Nov 1, 2006 10:20 PM
