Temp sensor change?
OK so the Volvo is still starting right up but then it dies a few seconds later, started looking at the temp sensor and found that it has a single prong spade connector on it? Every replacement one that I have looked at has two prongs on it and the plug has two prongs and two wires on it. My connector only has one wire on it? Is it possible that they replaced it? And if so where did the second wire go ![Confused](https://volvoforums.com/forum/images/smilies/confused.gif)
and what does it do?
OK so now I found the temp sensor, the listing at the part store did not show any single prong ones so we kept looking and looking and lo and behold at the bottom of the list there was a single prong one. Book says the range should be between 2900to 2100 when cold and 250 to 300 when warm. When ours is cold it is only reading 1300. Do you think this would be enough to make the car stall out based on the fact it is not getting enough fuel?
keep looking its buried under there! Good luck
Well I just checked the old one and I got 3500 on each side. I checked the new one and I got 2600 on each side. Do you think that the extra resistance in the old one could be sending too much fuel/air to the engine and making it stall out? Want to know what you guys think before I swap it out. Like I said this is my first Volvo so don’t know how finicky these things are as far as the computers/electronic circuits. Thanks for all/any of the help so far. Loving this for forum👍🏿👍🏿
Yes, they were very close in temperature. I was getting kind of frustrated by the whole temp sensor so I decided to pull off throttlebody and clean it. It was very dirty. Also cleaned the hose going from the MAF to the throttlebody. Found seven reps in the boot! Clean them up and patch them all put it back together, it is running better but still not great. More updates to come
#17
jupoloopo
07-29-2014 09:13 AM
