temperature gauge issues
Old Aug 23, 2023 | 07:00 PM
ruralmike's Avatar
Default temperature gauge issues
I note that the temperature gauge on my 1988 740 (b230ft) does not appear to be working. I have learned where the sensor is located, thanks to previous posts. It has 2 wires - a black/yellow and a yellow. Assuming I can get at the little bugger to pull the plug off of it, an I correct that I ground the solid yellow wire to check the gauge? If the gauge moves, the sender is bad. I see a lot of different brands of sensors are available. Are there any recommended brands? And if the gauge does not move, what then?
volvodriver99
Sep 28, 2019 10:33 PM
Blakelyons
1998-2000 model year V70
Aug 27, 2017 03:45 PM
amazon2
Jul 29, 2016 10:18 AM
MN740GL
Jul 4, 2008 12:34 AM
montysano
Mar 1, 2007 10:52 PM
