Tensioner for timing belt in original position.
Old Jun 28, 2011 | 02:46 AM
Daltino4's Avatar
Default Tensioner for timing belt in original position.
I was changing the timing belt and didn't know I had to put a pin in it to hold the bolt from going into its original position. My question is, how do I get it back in position to put tension on the timing belt?
Old Jun 28, 2011 | 08:50 AM
swiftjustice44's Avatar
Do you see the bolt in the center of the tensioner? I loosen it, pry it out of the way and then tighten it back down to change the belt. After the belt is changed, all one does is loosen the bolt, allow it to snap into position, and snug it down.
Old Jun 29, 2011 | 05:27 AM
Daltino4's Avatar
Thanks! I eventually figured it out. Spent 12 hours in 2 days replacing the timing let and when I put it back together and try to start it, it idles and dies. Obviously I didnt line the notches up right so I gotta tear it apart and try again this is my first time ever working on a car.
skydivetoday
May 10, 2012 08:58 AM
outdoor7or24
Dec 22, 2008 09:35 AM
FBookhoo
Oct 25, 2007 04:41 PM
MikeySq
Oct 18, 2006 10:01 AM
Moparman
Oct 17, 2005 08:33 AM
