Timing hesitating in idle but ok at high RPM's
Old Sep 26, 2019 | 05:01 PM
Dagaan's Avatar
Default Timing hesitating in idle but ok at high RPM's
1986 DL240 - While trying to turn my stuck distributor I knocked the clamps off the distributor and then drove not knowing I'd done this. I replaced the chewed up dist cap and rotor but now the timing or something is off. I looked at the timing with a timing light last night and saw that the timing is way off in idle but is fine at higher RPM's. What I'm wondering is - is there some electronic mechanism that has to do with timing? Seems I've heard that mentioned somewhere. Also - my distributor is really hard to turn - I've never done it. A shop did it and when I asked how he said 'I wacked it with a hammer'. OK. I tried a bit of that too - using a chisel aimed at the little loop where the tightener bolt is. But as there is little room to hit it - counter clockwise - I quit as there's not room at all to hit it clockwise if I mess it up. Advice?
Old Oct 2, 2019 | 01:08 PM
this is a US model 1986 ? the timing is done in the Chrysler ICU thats behind the right headlight, on the inside of the fender.... this has a vacuum hose to a bellows similar to a vacuum advance distributor, and also simulates RPM based advance electronically. the master timing signal comes from the hall sensor on the distributor up til 1989 when they switched to a crank position sensor along with LH 2.4 and EZK bosch ignition.
if its a world market '86, it could use a different system, I am not very familiar with those.
Old Oct 3, 2019 | 02:00 PM
Dagaan's Avatar
Thanks Pierce - I think It's Swedish made - but it gives me a clue.
Old Oct 3, 2019 | 02:17 PM
I meant, is it a car sold originally in the US... the models sold in other parts of the world often have different fuel injection and ignition systems, or even carburetors, depending on the year.
Old Oct 8, 2019 | 11:33 AM
Dagaan's Avatar
I don't know if it's a world market or not.
daver80
Jul 29, 2019 12:08 PM
Sleipnir
Dec 9, 2017 07:20 AM
patwguinness
Apr 25, 2011 11:15 PM
im4rcn
Mar 10, 2010 10:55 AM
undercoverwalrus
Sep 25, 2007 07:26 PM
