Regina 2 pump fuel injection!!
Old Oct 7, 2019 | 09:19 PM
Goldenblock's Avatar
Default Regina 2 pump fuel injection!!
Do any of you guys have this setup on your regina volvo??
I have 89 volvo 740gl non turbo
Non abs non egr.
Osss
Old Oct 7, 2019 | 11:51 PM
regina EFI has the same rail pressure and flow requirements as LH2.4, so it will work with the bosch dual pump setup. I've heard of all sorts of things, like cars with Regina injection but Bosch ignition, etc. Volvo would mix and match whatever parts they had on hand if they ran low on stuff.
Old Oct 9, 2019 | 11:31 AM
In your professional opinion and experience... Is one pump more reliable vs dual pump system??
Thanks brotha
Old Oct 9, 2019 | 12:07 PM
many newer cars, such as the 850, use a single pump in the gas tank. in fact, I've heard you can retrofit a 850 fuel pump to a 240 or 7/940 pump+sensor assembly with a bit of tinkering, and customizing the hose lengths... the fuel flow and pressure requirements are compatible (use the 850 t5 turbo pump for a 740/940 turbo).
david12345
Aug 17, 2015 08:49 PM
floz313
Oct 20, 2013 04:36 PM
oilman940
Oct 15, 2012 07:50 PM
BassGuy
Aug 28, 2010 08:52 PM
Stevenosteven
May 11, 2010 09:10 PM
