Torque rod bushings
Old Jun 14, 2007 | 06:38 PM
jkevin's Avatar
Default Torque rod bushings
Just got a very clean 1990 240DL wagon for my son. Started with front muffler, then moved on to rear shock replacement, then realized torque rod bushings were goners, got complete rear kit. Had the driver's side TR's pressed out and replaced today. My son reinstalled, then test drove and heard lots of new noise. The rear bushing is sliding back and forth in the housing. Any ideas for a solution? Tack weld? Big hammer?
Thanks!
Old Jun 15, 2007 | 07:16 AM
JetTech's Avatar
Default RE: Torque rod bushings
The bushing shouldn't be sliding in the torque arm, if so you may have installed the wrong ones from the kit. The panhard rod bushings are a little smaller then the torque rod bushings. Is there a chance you installed those by mistake?
Old Jun 15, 2007 | 08:43 AM
jkevin's Avatar
We batched the 4 bushings according to part # and size. The panhard rod bushings are separate. My question was not about confusing the bushings, but how to mitigate a problem with the "correct" one. I am quite sure that mistake was not made. Please help me focus on the problem.
Old Jun 15, 2007 | 06:06 PM
jkevin's Avatar
I have established that the correct bushings were installed. Can anyone offer a suggestion for a solution to this problem? The 4 bushings were esssentially identical, though I didn't mic them. I heard back from the vendor, who will exchange them. Has anyone heard of an oversize problem with the rod itself? One end is tight and both the old ones (OEM Volvo) were quite thoroughly fused in, so the replacement was undersized?
Should I perhaps go with urethane?
modifierwong
Jun 4, 2014 08:32 AM
IRMB
Sep 1, 2012 07:01 PM
kapka42
Jun 22, 2011 10:53 AM
sandraqu
Dec 24, 2009 02:36 PM
Platinum52
Jul 17, 2009 07:33 PM
