Towing 240 station wagon by tow bar?
Old May 1, 2017 | 07:09 PM
tat1642's Avatar
Default Towing 240 station wagon by tow bar?
Hi,
We are planning for cross country USA, moving with 26 Feet rental moving truck with tow bar, attached our 93 Volvo 240 station wagon behind.
Does anyone can advice us for experiences or brand of tow bar to purchase?
Is it better detach the drive shaft?
Thank you!
Old May 1, 2017 | 09:44 PM
I wouldn't flat tow an automatic. best thing to do is tow it backwards, with the rear wheels on a 'cradle' trailer aka dolly, like this, https://www.uhaul.com/Trailers/Tow-Dolly-Rental/TD/ (but backwards for RWD, with the steering wheel lashed in place).
Old May 2, 2017 | 06:01 AM
act1292's Avatar
If you want to use the tow bar and your car is an automatic, then yes, you must disconnect the driveshaft. If you use a tow dolly as Pierce suggested you can leave the drive shaft connected but you must place the rear wheels on the dolly and lash the steering wheel.
Old May 2, 2017 | 09:07 AM
tat1642's Avatar
Thanks Pierce and Act 1292 !!
We called moving truck company and price was not bad as we thought. All 4 wheel up transporter which no need to take driveshaft out, cost was 300+, for cross country trip.
We are going to do this way, probably safer than thin metal construction tow bar from Harborfreight.
Old May 2, 2017 | 12:57 PM
silvermine's Avatar
good for you. guess it would cost more than 300 in gas alone if you were to drive it x-country.
takawiram
Sep 18, 2015 10:44 PM
bangers2u
Aug 8, 2011 01:21 PM
pierce
Nov 19, 2010 03:55 AM
mikewells
Jun 28, 2010 07:40 AM
TonyB
Dec 16, 2006 08:42 AM
