Tranny problems in 240 DL !
I bought a 1990 Volvo 240 DL Station Wagon and it has 176,000 miles on it. When I first took it for a test drive last Saturday everything worked fine. Last Monday the seller called to tell me they took it on a final farewell drive and it wouldn't upshift ( Its an automatic transmission ) past second gear so it only goes about 20 mph !
I took a gamble that its not a complete failure but rather a sensor or something. I paid 400.00 for the car.
Any ideas as to what it could be ?
Also , when doing the front ball joints does the coil spring have to be compressed before you remove the old balljoints ?
Check to see if the upshift cable on the car is stuck that would hold it from going into you're more road friendly gears.
I haven't done a ball joint on a 240 in forever, but i believe I i just un bolted it and didn't need to compress anything. I'm sure it would make it easier if you had a set.
