Transmission Help!
Old Mar 11, 2009 | 02:09 PM
Martino's Avatar
Default Transmission Help!
So tomorrow I am going to pick up a 75 244 GL that has trans problems...
I'm new to the Volvo world and am excited to get into this 244. It's a beautiful car, just needs a little love to be back on the road. Here's what I know:
-transmission will drive in R and D but will not up-shift (kick down cable?)
-when last started (3 weeks ago) seller says it didn't want to idle properly, like it wanted to die when in neutral or park, this is when he noticed it not shifting...
could it's low idle be causing it not to shift?
any help is greatly appreciated... again, this is my first encounter with the Volvo world, so bare with me, i may ask some stupid questions...
Old Mar 15, 2009 | 08:53 PM
TIPSP's Avatar
Got Boost?
Default Bump
tedv, bubba, cbevis, tech....etc...any thoughts?
Old Mar 16, 2009 | 10:24 AM
tedv's Avatar
Check the fluid, if it's ok, the tranny is probably bad.
Old Mar 16, 2009 | 01:33 PM
Martino's Avatar
Fluid was low and dirty... I will drain and refill with fresh after i change kick-down cable, which has about .5-1" of play when adjusted as tight as it will go... seems too loose to me... any other thoughts?
thanks,
marty
Old Mar 16, 2009 | 06:14 PM
tedv's Avatar
How many miles?
Let's hope you get lucky!
Old Mar 17, 2009 | 11:28 PM
Martino's Avatar
138,900 miles...
I guess I did get lucky... I scored a known good BW35 from a friend so I'll just do the swap and see what happens...
mason3325
Dec 22, 2021 12:51 PM
jeffrisley
Jun 14, 2015 01:48 PM
talon0930
May 23, 2010 09:07 AM
