transmission problem
Hello,
I would suggest you start by checking the level of your transmission fluid. Second, have you accidentally depressed the small switch on the left side of the gear selector? I manually over-rides shifting into 4th gear for towing purposes. If you have, you will notice an orange UP arrow lit on the right side of the instrument cluster.
Andrew
Andrew
There are 2 places to look. There is a OD relay in the fuse area below the radio that usually goes bad. The default is not to up shift to 4th gear and OD. Then there is a solenoid on the transmission that diverts the fluid to 4th gear OD. Check those first to see if one is bad. With the key on ACC press the button on the shifter and you should hear the relay under the radio click. Start there.
mason3325
12-22-2021 12:51 PM
jeffrisley
06-14-2015 01:48 PM
bradvdl1
12-04-2013 06:39 PM
icehouse719
11-10-2010 03:31 PM
