Trying to fix my speedo
Old Jan 11, 2006 | 05:58 PM
Kruspe31's Avatar
Default Trying to fix my speedo
I have a 1990 740 Turbo and the speedometer/odometer doesnt work. I bought the car this way and now i want to fix it. Also the antilock brake light is on, I remember i read somewhere that when the anitlock brake light comes on the speedo will not work? Also the mechanic checked the speed sensor and he said it was fine, I even put in 2 different clusters and it didnt fix it.
Old Jan 11, 2006 | 11:40 PM
Default RE: Trying to fix my speedo
Check the wiring from the Rear speed sensor.
If that is ok then you will need to back track from there.
Old Jan 12, 2006 | 03:59 AM
Kruspe31's Avatar
yes i forgot about asking about that. now next time i get an oil change i will look for that, I am getting one soon. now is the wires in the pumpkin? or someplace else? also how do I remove my windshield wiper fluid bottle, it doesnt work and I need to put in a replacement
Old Jan 13, 2006 | 09:39 PM
Yes the wires in the Pumpkin.
I forget exactly about how to remove the bottle. There should be a screw or 2 holding it in.
I haven't taken one out in about 3 years.
Old Jan 15, 2006 | 11:28 PM
Kruspe31's Avatar
well thats good, i could always have the mechanic change the rear oil in the pumpkin and he can look at the wires. can he check them with a meter to see if its good or not?
Old Jan 17, 2006 | 08:43 PM
There is a way but I don't have the specs here.
Old Jan 17, 2006 | 09:47 PM
wojeepster's Avatar
you could check the wires from the pumpkin one should show a pulse if you use a logic probe. The speedo gets powered straight from the ign switch on my car this is a black wire with a red stripe. This wire with the two from the pumpkin plug into the back of the speedo. If this power wire is not plugged up the car will not start because it supplies voltage to all the other lights on the dash and power to the coil. So you know you already have this so the two wires to the pumpking or the pickup on the rear end is probably at fault. Sensor is quite expensive I think I saw it somewhere for $120 the two wires come into the trunk along with the wires for the in tank pre pump. hope this helps
Old Jan 22, 2006 | 03:26 PM
igtc's Avatar
Curious, I just recently made a post about my odometer. I have a 90 740 GL Rex. Did you ever get your speedo fixed.
My problem is not the speedo, but odometer. My speedometer works fine. You can read the post just a couple of days ago.
How did you fix it, if so?
Thanks,
Kevin
Old Feb 23, 2006 | 02:03 PM
b230ftR's Avatar
youre all screwed. they can't be fixed, already tried, already cried
Old Jun 12, 2006 | 02:31 PM
kurtz075's Avatar
Please explain??
ORIGINAL: b230ftR
T1Runner
Sep 28, 2011 09:54 PM
k
Oct 19, 2009 02:10 PM
theotherpilot
Jul 10, 2009 12:28 AM
Mikeman
Feb 11, 2009 03:56 AM
Volvorator
Mar 15, 2007 10:37 AM
