Two questions: 1)idle control motor 2) ignition coil
Old Jan 12, 2008 | 11:53 AM
montysano's Avatar
Default Two questions: 1)idle control motor 2) ignition coil
Idle control motor: upon testing with my newly arrived Bentley manual (yes!), I find that the throttle body switch on my '90 240 is bad. It never completes the circuit to open the idle control motor. The question is: if I uplug the idle control motor and shoot 12v straight from the battery to it, could I do any harm. I just want to see if the motor is working correctly (it appears that it does) and see how the car idles before I order the switch.
Ignition coil: does Volvo/Bosch use some special spark plug and coil wires? I just replaced the coil, and on both the new one and the old one, the coil wire connection seems tenuous. I plug it in, but the coil seems to spit it back out. It works; it runs; and it's never come loose during use, but it disturbs me [:@]
Old Jan 12, 2008 | 12:18 PM
Default RE: Two questions: 1)idle control motor 2) ignition coil
1. Not sure if it will hurt it or not never tried.
2.The coil connections are wacked on those coils.
Old Jan 12, 2008 | 12:39 PM
montysano's Avatar
I guess the question is: does the idle control motor get a full 12v during operation, or is it stepped down? Bentley says to test the motor with straight 12v, so I think it probably wouldn't hurt.
I could even wire up a temp switch until the new switch gets here
fochs
Jun 11, 2015 10:56 AM
Ricardito
Aug 14, 2012 08:29 PM
jbuck
Nov 16, 2011 05:48 PM
vwagon
Dec 28, 2005 01:37 AM
