UK spec "1992 Volvo 240 se non starter"
Old Jun 17, 2008 | 04:42 AM
Welshman's Avatar
Default UK spec "1992 Volvo 240 se non starter"
Hi, can someone please help? Engine turns over but will not start. Checked error codes onboard diagnostics. Terminal 2 flashes 1..1..1, seems ok? Terminal 6 light glows faintly when ignition is switched on goes bright when test button pressed then goes dim again when button released NO flashes. At the same time the ignition is switched on there is a buzzing/arking sound from the distributor. Testing the spark plugs by earthing shows a faint flickering spark when ignition switched on but nothing when engine cranked over. Incidentally, engine does not attempt to fire even when towed. Car had been idle for a few weeks and started no problem, then had to try a few times before firing for 2 –3 days. Now wont start at all.
cb1313
May 23, 2009 11:49 AM
lata
Mar 20, 2008 03:45 AM
theviper
Dec 21, 2005 01:16 AM
reriver
Sep 1, 2005 10:15 AM
mr
Mar 31, 2005 12:16 PM
