Vacuum sound from behind center console on 240
Old Sep 12, 2010 | 11:32 PM
kurdtpatton's Avatar
Default Vacuum sound from behind center console on 240
I have a 1991 240 wagon. There's a loud vacuum sound that comes from the center console that sounds like the vacuum tank filling with air every time I accelerate or leaving the tank when I shut off the car. At first I got scarred cause I thought it was the transmission. I didn't know there was a tank back there. I just recently got this car and never had a volvo before. I've never had a car make this noise. Is something in my vacuum system shot? or is this just normal?
Old Sep 13, 2010 | 07:11 AM
act1292's Avatar
There is a vacum reservoir that sits in the center console that runs all of the heater flapper valves in the dash. A vacum line runs from the intake manifold through the firewall and feeds this reservoir. Right on the intake manifold you will see there is a little plastic valve - I think it is black & white. Pull this valve off and blow through each end. If you can get air to flow both ways, then the valve is bad. Replacements are cheap and can be found on FCP Groton
I had this problem on several of my cars. Good luck.
Old Sep 14, 2010 | 03:41 PM
You rock
LittleMushi
Jul 21, 2015 09:00 PM
Carbonlite
Mar 26, 2015 08:11 PM
shelby187
Jan 8, 2012 03:59 AM
big daddy russ
Jan 17, 2010 05:27 PM
copycat923
Dec 20, 2005 08:57 PM
