valve lash on a 940
Old Sep 5, 2005 | 10:42 PM
Buck's Avatar
Default valve lash on a 940
I hear the valves ticking at low RPM's on my 940. Anyone know the tolerance on these valves cold???
Old Sep 6, 2005 | 05:34 PM
Ignavus's Avatar
Default RE: valve lash on a 940
Cold engine clearances intake and exhaust valves; checking 0.30-0.40mm ( .012-.016 in ), adjusting 0.35-0.45mm ( .014-.016in)
Old Sep 6, 2005 | 08:14 PM
Carbuff's Avatar
ORIGINAL: Buck
The specs are on a sticker near the left front strut tower on my '94 945. Or from Ignavus' post.[:-]
If the clearances are in spec but you still hear valve tap, either live with it...or replace the rubber silencers AKA "Hushers" under the camshaft.
Hushers
Old Sep 7, 2005 | 01:40 AM
matthewensey's Avatar
Be careful, the ticking you hear may just be the fuel injector needles opening and closing. Very easy to mix the two up. Put a screwdriver "point-down" on the injector, and place the handle to your ear. Then, do the same on the valve cover, that will help you ID where the noise is coming from. Not to say you aren't hearing valve noise, but I've had a lot of people be suprised when I tell them everything's OK, and just run a fuel injector cleaning.
Old Sep 17, 2005 | 12:11 AM
Buck's Avatar
The Valve lash is at .015. What are these "hushers" that you talk about? I didn't see any rubber bushing in the valve cover.
Old Sep 17, 2005 | 11:46 AM
If there is to much play between the cam and the lifters you will have to install thicker shims to take up the space.
Old Sep 17, 2005 | 11:57 AM
Carbuff's Avatar
ORIGINAL: Buck
Hi Buck,
Click on the blue word HUSHERS in my previous post, it will connect you to a link that explains everything.
They are under the valve shim disks so you can't see them. They come in a headgasket service kit (or individually, I suppose). You have to remove the camshaft to replace them (not as daunting a job as it seems on a Volvo engine).
Simply put, they are rubber cushions that minimize valve tap that can be evident with solid lifter designs.
rhayles
Oct 24, 2012 11:02 AM
Rakam
May 27, 2011 09:03 PM
chachouu
Apr 8, 2010 03:51 PM
poor_red_neck
Apr 16, 2009 06:31 PM
mygreenbomb
Feb 29, 2008 06:09 PM
