Vapor Lock?
Old Jul 7, 2017 | 06:34 PM
bigarms24's Avatar
Default Vapor Lock?
I have a 240dl 1988 I replaced the inline pump and fuel filter almost two weeks ago and I was driving when to make a turn smelled gas and it died after I pushed it for 4 blocks in Arizona heat 112 I let it rest for an hr and it fired right up I left it parked at the hospital and am wondering is it vapor lock or a faulty pump I bought a new pump 1 month ago and that one did the same thing so I warrantied it after the hr it started again its got 1/2 a tank of gas any advice would be great
Old Jul 7, 2017 | 08:11 PM
madman77's Avatar
Vapor lock only happens on carbureted engines not fuel injected. Something else is going on, maybe a leaky fuel line?! (smell of gas).
Old Jul 7, 2017 | 08:22 PM
bigarms24's Avatar
nothing was leaked on the ground though could the new pump be a dud
Old Jul 8, 2017 | 10:51 AM
madman77's Avatar
Here's a video of something you should check first before you blame the fuel pump.
Old Jul 8, 2017 | 11:55 AM
bigarms24's Avatar
ill take a look
Old Jul 12, 2017 | 01:31 PM
cleanflametrap's Avatar
Default Vapor lock
Vapor lock is not just a carb thing. It is reality in your two-pump setup.
If the tank pump fails, vapor lock is what keeps the main pump from creating pressure. If the regulator valve leaks back, or the main pump's check valve leaks back -- anything that forces the fuel as fluid from the main pump -- the system is vapor locked. Just wait until it cools.
Or fix the tank pump. Make sure the rail pressure is maintained for at least 20 minutes after shutdown.
http://cleanflametrap.com/transferPump.htm
Old Jul 13, 2017 | 12:01 PM
bigarms24's Avatar
The pump on the frame got too hot I warrantied it yesterday
Old Jul 22, 2017 | 07:25 PM
silvermine's Avatar
just out of curiosity what brand of pump are you using?
Old Jul 22, 2017 | 10:06 PM
bigarms24's Avatar
the only one my local oreilys auto has I think its a specter pump but out of the 2 auto part stores in my area its the only pump they can get
Old Jul 23, 2017 | 07:01 AM
chain car parts stores are good for Honda and Chevy parts, not european cars. get stuff mail order from European specialists like FCP Euro or IPD USA.
Old Jul 23, 2017 | 07:02 AM
only stuff I buy at OReally or Autozoned is wax, antifreeze (Zerex G-05), and oil, and maybe wipers.
Old Jul 23, 2017 | 09:01 AM
silvermine's Avatar
well that may explain your problem. surely the heat doesn't help but
think you would do better with bosch. fcp euro guarantees everything forever
and free shipping to your door.
Old Jul 23, 2017 | 12:13 PM
bigarms24's Avatar
I would but I needed to fix it asap due to having to work so I used what 1 I could afford and 2 I could get same day
Old Aug 14, 2017 | 12:31 AM
91-740Turbo's Avatar
My 740 vapor locked on me going south from Atlanta with the stupid McDonough traffic on one hot summer day. I knew I had spark with a new coil and plugs a week before. Having nothing else to do on the side of the road i pulled the carpet back in the trunk and removed the access panel. Removed the pressure line for the in tank pump to the pressure pump and there was nothing.
I then sat on the side of the road for a few moments and then placed everything back in order and primed the fuel. Started back up and then went to grinding for another 45 minutes to go 6 miles past a wreck when the pace picked back up.
I already knew my in tank pump was failing, replaced it a month later.
fmowr
May 2, 2014 11:44 AM
1995Volvo850
May 24, 2012 08:57 AM
91-740Turbo
May 21, 2012 01:28 AM
curtorous
May 11, 2012 12:49 PM
browntrout
Aug 1, 2006 07:23 PM
