Very Slow 240 Wagon
Old Jun 27, 2016 | 05:16 PM
Nichals's Avatar
Default Very Slow 240 Wagon
I've got a 1991 240 Automatic Wagon
Now, I know the redblock is tiny, and the car is huge, but this car seem unreasonably slow. Ive had other 240's that have been quite a lot faster, but never a different wagon. Does the extra 2-300 pounds really make that much of a difference.
whats happening is that it may loose speed going up hill, and unless I make the car kick down it won't accelerate past 80.
any help? maybe off on the timing belt
possibly clogged fuel filter
Old Jun 27, 2016 | 05:18 PM
Nichals's Avatar
Also, even with primary highway mileage I always average 17 MPG
Old Jun 27, 2016 | 06:21 PM
silvermine's Avatar
is this the same car that won't shift into overdrive (4th)?
17mpg is way too poor
Old Jun 27, 2016 | 07:50 PM
Nichals's Avatar
Nope, good eye tho!
I have a 1991 wagon
My wife has a 1992 sedan with a transmission issue (which by the was is full of seafoam)
Old Jun 27, 2016 | 08:31 PM
Cwazywazy's Avatar
Maybe the hot air intake is stuck open?
Old Jun 27, 2016 | 08:45 PM
Nichals's Avatar
I removed th hot air intake completely, pipe and all.
I live in Texas after all
I as more worried that it would get stuck and burn up my MAF
Old Jun 28, 2016 | 06:04 AM
act1292's Avatar
Are there any engine codes?
Given the mileage and poor performance my first thought was that it is in open loop or "limp home" mode. This means it wouldn't use the sensors to regulate fuel. You would have codes in this case.
Clogged cat is another potential problem yet I wouldn't think it would cripple your mileage
Last thought would be the timing belt slipped a tooth
Old Jun 28, 2016 | 03:29 PM
Cdubbs's Avatar
Could it be a bad/faulty oxygen sensor causing the poor gas mileage? Bad readings might throw off the air:fuel ratio
Old Jun 28, 2016 | 04:06 PM
Nichals's Avatar
No engine codes at all, even so I just reset the system by unplugging the battery for about 5 hours to establish a baseline
It really seems like a slipped tooth to me, because its hard to start cold or hot, but it runs pretty smooth...
@Cdubbs
As for the O2 sensor, I could try changing that, is there a way to test it?
I thought the CAT was clogged too however I took it off to find that it was gutted, completely empty...so definitely not clogged lol
Old Jun 28, 2016 | 04:28 PM
Cwazywazy's Avatar
I have no idea if you can test o2 sensors, but you do have another Volvo sitting around right? With a good o2 sensor?
Old Jun 28, 2016 | 05:29 PM
Nichals's Avatar
Yeah but this thing is so rusted in I don't know if I can get it out with ought destroying it
looks like Ill just replace it looks like about $50
hmmmmmmmm
Old Jun 28, 2016 | 09:26 PM
Cwazywazy's Avatar
I'd see if you could test it before spending the 50 bucks. How much stuff would you have to remove to check the timing?
Old Jun 29, 2016 | 06:06 AM
act1292's Avatar
O2 sensor would throw a code. My guess lies with the timing belt. Not a too difficult job to check the timing marks. If the belt has unknown mileage on it I would just do a replacement since you will need to pull off all the covers and pulley.
Old Jun 29, 2016 | 12:28 PM
Nichals's Avatar
Good point, no codes
The guy who had the car did all of his own repairs and wasn't very good. The belt is almost new according to his records, so that in my mind adds weight to it being the issue. Its cheap and easy to change, so ill tackle that and let you guys know how it goes.
yarchlrl
Nov 9, 2014 12:28 AM
hardluck
Mar 3, 2012 02:20 PM
2004VolvoS60_Bilal
Aug 3, 2010 04:29 PM
nicolaselias
Sep 18, 2009 08:51 PM
tr_car_nut
Jan 19, 2008 09:57 AM
