Volvo 240 86 station Fuel problem
Old Aug 28, 2013 | 08:06 PM
phauk10's Avatar
Default Volvo 240 86 station Fuel problem
Alright so i have had a lot of work done to my Volvo 240 86 station wagon dealing with the fuel line. Got a new pre-pump, main fuel pump, fuel pump relay and the ignition coil all new and installed. But my Volvo still sometimes bogs down on me. And will not catch trying to start it. Frustration wont start sometimes after all this work and leaving me stranded. What do you think it is?
Old Aug 28, 2013 | 11:00 PM
Titan Joe's Avatar
You looked at the fuel pressure regulator or the engine temp sensor? You got any vacuum leaks? I'd eliminate those first.
Old Aug 29, 2013 | 12:06 AM
i'd start at the vacuum leaks, and intake air duct leaks (between the MAF and the engine), THEN test the temp sensor (easy test, just need a digital multimeter), then look at the fuel pressure (easiest to find someone with a fuel pressure tester and have them do the test for you).
oh, quick fuel pressure regulator test tho... unplug the vacuum line behind the FPR, is it wet with fuel residue? if so, then the FPR goes up to the top of the suspect list and should be replaced immediately.
Old Aug 29, 2013 | 02:02 AM
phauk10's Avatar
do u guys think i might just need to buy a new Main Air Flow sensor??
Old Aug 29, 2013 | 02:42 AM
find another LH2.2 car (msot any 240/740 1985-1988, they all use -007 MAF's) and swap the MAF with it. its 2 about minutes with a screwdriver. if the other car inherits your problems and yours works, then yes, you need a MAF, give the guy his MAF back and find one in a junkyard or whatever..
watch out for noname rebuilds. quality is all over.
rjdaaa
Oct 18, 2014 09:12 PM
Mustsail
2001-2013 model year V70
May 10, 2014 02:44 PM
old car young dude
Jun 26, 2012 12:07 PM
luchauer
Jun 21, 2012 06:40 PM
cubentrix
Jun 3, 2011 08:43 AM
