Volvo 240 Hot Start Problem?!
Old Jul 17, 2018 | 03:56 PM
Sufarry's Avatar
Default Volvo 240 Hot Start Problem?!
Alright, so not much wrong with the 240, however it does have problems on warm starts. It drives fine, no power loss or anything, just hard to get started once the motors warmed. Should add, that when the engine is cold, it starts right up and seems to idle fine.
From limited research, I’d assume it’s he coolant temp sensor for the ecu, not the gauge. From what I understand it basically tries to start the car as if it was a cold start?
Also was told to check the fuel pressure regulator vacuum line for the smell of fuel. I checked, and it does smell like fuel. Could this be causing this issue?
I feel like a bad fuel pressure regulator would cause cold start problems too?
Any guesses?
Should also add, the gauge goes straight to hot even if the engine is cold.
Pfa.
Old Jul 18, 2018 | 06:06 AM
act1292's Avatar
Bad fuel pressure regulator can cause hard warm starts. Best way to check it is to put a fuel pressure gauge on the rail and measure it. Here is a good description https://www.brickboard.com/FAQ/700-9...sure_Regulator
Old Jul 18, 2018 | 11:28 AM
Sufarry's Avatar
Thank you for the reply! I ordered a new FPR, lets see how it goes! I'll keep this updated!
Old Jul 21, 2018 | 06:42 AM
John Arsenault's Avatar
When my FPR was letting go I did not get fuel coming out of the vacuum line but if I let my car idle for a period of time it would start running real rich and start stumbling, if I let it idle longer it would eventually flood out and stall. I had no hard starts hot or cold.
Old Jul 21, 2018 | 06:55 AM
silvermine's Avatar
that pic looks exactly like one in an ad on craigslist of a 240 for sale in gainesville,ga ...??
Old Jul 21, 2018 | 08:41 AM
Sufarry's Avatar
it is! I traded my 2006 Ford Focus for it!
Small world lmao!
Old Jul 21, 2018 | 07:49 PM
silvermine's Avatar
Small world lmao!
you got a very good looking 240.. up here we don't see examples that clean...
good luck!!!
George4
Sep 17, 2016 04:34 AM
bksmartit
Feb 10, 2016 05:03 PM
GrantRobertson
Jun 1, 2013 04:04 PM
theequalizer
Oct 20, 2012 08:57 PM
SamMonk
May 27, 2010 08:25 PM
