Volvo 240 Winter Tires, what sizes?
Old Jan 2, 2013 | 09:00 PM
tbuchan's Avatar
Default Volvo 240 Winter Tires, what sizes?
Hello I have a 1993 Volvo 240 Wagon and wondering what sized tires will work with my car.
New to this site so Im hoping I can get some help
Thanks
Old Jan 2, 2013 | 09:39 PM
does the car have the stock 14" rims? P195/75R14, 92S or T.
there's a fairly limited selection in those these days, sigh.
If you have 15" rims (optional aftermarket, or volvo OEM dealer options), then P205/65-15 94T or 94S will work nicely. The rims off most any Volvo 740/940, they'll bolt right on and be perfect. if you get aftermarket rims, they have to have the correct offset as well as bolt pattern, the wheels from a front wheel drive Volvo will NOT work without spacers.
Old Jan 4, 2013 | 12:35 AM
tbuchan's Avatar
no they are stock rims, on the car, p185/75r14 89S are the tired i have on now, any chance you could explain these numbers?
Old Jan 4, 2013 | 01:04 AM
ah. 185/75r14 is the standard size on a 240 sedan. wagons actually got the larger, and heavier duty 195/75-14 but those are somewhat hard to find.
on P185/75R14 89S...
  • P means passenger tire
  • 185 is the sectional width of the tire
  • 75 is the 'aspect ratio' (smaller number is a lower profile tire, and has a shorter sidewall)
  • R means its a radial
  • 89 is the load factor, larger number handles more weight safely
  • S is the speed rating. S is 112MPH, T is 118MPH. H is 130MPH, V is 150MPH, and Z is over 150. there are others, but these are the most common.
with 185's, your wagon's speedometer probably reads just a hair higher than your actual speed, since it was calibrated for the slightly larger 195's (bigger tire goes farther per turn). more specifically, the 185's are 835 turns/mile, while the 195's are 815 turns/mile. if you are actually going 60MPH, with the 185s, your speedometer will read 61.4MPH. thats a pretty small error, well within most people's 5MPH tolerance.
P195/75R14 has become a fairly rare size, so a lot of people will substitute the 185's. so yeah, you can use 185/75R14 snowtires. For summer use, P205/70R14 would be closer to the standard wagon diameter but slightly wider, and is typically a 93 or 95 load factor tire.
Old Jan 5, 2013 | 03:24 PM
tbuchan's Avatar
Thanks a lot, I really appreciate it, off to look at some tires now
Thanks for the help
Old Jan 5, 2013 | 10:10 PM
swiftjustice44's Avatar
Firestone Winterforce
Old Jan 18, 2013 | 02:43 PM
tbuchan's Avatar
I have been told i can use 15 inch rims without having to adjust any of the bolt pattern? Ive tried numerous places and no luck on the 14 inch rims. Any info would be great.
Thanks
Trevor
Old Jan 18, 2013 | 02:45 PM
tbuchan's Avatar
"The rims off most any Volvo 740/940, they'll bolt right on and be perfect. if you get aftermarket rims, they have to have the correct offset as well as bolt pattern, the wheels from a front wheel drive Volvo will NOT work without spacers"
Does it matter the year of the 740/940?
Thanks again
Old Jan 18, 2013 | 05:54 PM
Any 740 wheel as they stopped building them in 92. At some point, the rwd went to a fwd offset...I know the 98 S90 had the fwd offset even though it was an rwd car.
Old Jan 18, 2013 | 07:39 PM
only the last 2 years of 960 when they got the facelift that looks like the S90/V90 use the FWD offset. no US model 940 used the FWD offset, although there were some in the rest of the world, these would be later than 1995.
all the rest of the 740, 760, 940, 960 and of course, all 240's use the same bolt pattern and offset. the wheels are fully interchangable, except you can't put 14" 240 wheels on 7x0/9x0 models that have the bigger front brakes, like the turbos.
Old Jan 18, 2013 | 10:01 PM
if you go for aftermarket wheels, you want 14 or 15", with a 5x108mm bolt pattern, and a +20-25mm offset. you want relatively narrow rims, like 14x5.5 or 15x6. the bolt pattern supposedly is interchangable with some 5-bolt fords but I have no idea if the offset is the same.
Old Jan 21, 2013 | 07:37 PM
tbuchan's Avatar
Thanks again for all your help
quick question how do i start a new thread for a new topic within this site?
Old Jan 21, 2013 | 07:48 PM
go to the main page for a given section, like Volvo 240, 740 & 940 Forum and click on the "New Thread" button on the left under the page header
petergreene
Aug 6, 2015 08:03 PM
Baldmccartney
Jul 19, 2015 07:07 PM
ms000
Apr 26, 2014 08:57 PM
drmgbrown
Aug 14, 2013 02:10 PM
rtich
Jun 11, 2011 04:50 AM
