Volvo 240 wont go past 2k rpm once warmed up
Old Dec 19, 2023 | 11:19 PM
Sulaymaan's Avatar
Default Volvo 240 wont go past 2k rpm once warmed up
I have a 1984 volvo 240 GL LH2.0, that runs ok it will rev up to redline although it does have a rough idle it revs up.. well until about 10 min of driving and once its warmed up, it starts bogging and wont go over 2k and sometimes 3k rpm. Sometimes if i give it barely any gas it will rev up slowly but if i put my foot down the rpm bounces slowly from 2k down, i changed the fuel filter about 4 times in 3 months each time was dirty, i also changed the intank pump 3 times i also did drain the tank. i just swapped the motor / block kept everything else sensors etc, i was having this issue before my swap so its got to be fuel related, my main fuel pump is mostly loud sometimes alittle quieter, i have 2 LH2.0 mass air flow sensors i swapped it still same. My thinking is i need to change the tank or wash it out, and change the filters and pumps once more? maybe convert to a single 255lph intank pump?, and change the 02 sensor i have a aftermarket one in, as well as the coolant temp sensor? its currently not reading anything but i was having this issue with my old motor and the coolant sensor was working.
Any advice would help thanks.
Old Dec 20, 2023 | 09:32 AM
Psaboic's Avatar
One way that I can think of is if you can drive it SAFELY using a 5 gallon gas can as your fuel supply and temporarily bypassing the main fuel tank. That should tell you if the tank is the problem. Again, the key word is SAFELY.....
Old Dec 20, 2023 | 07:12 PM
Sulaymaan's Avatar
Yeah so basically I dropped the tank, it's terrible the car was sitting for 17 years so.. yeah it's a lot of rust etc in the tank, insane how this thing went 6k miles like that. Thanks for your advice
Andreas Ledet
Oct 21, 2018 09:43 PM
Sleipnir
Sep 30, 2017 06:08 AM
Violetsjewels
Dec 13, 2015 06:36 PM
teegarterri
Dec 1, 2013 10:48 AM
b_faulk75
Nov 29, 2006 09:14 PM
