Volvo 740 Radiator Leak
Any radiator shop should be able to get you a direct replacement . Most of the newer ones are aluminum with plastic side tanks and are a direct fit.
If you want to fix it temporary, put some cinnamon in the radiator. Smells line christmas bit works fine! Done it many times. If you want a bryter substanser there's bar leak. A can in which you put the substance IN the radiator. GM uses that on their services. Can also fix engine problems. A bit costy but works fine.
The FC Plate went on fine but its a bit too shallow for the side bolts to line up, and it arrived with a small crack but, it does get a lifetime warranty!
