Volvo 940 Turbo and Volvo 940 engines
Old Dec 27, 2004 | 12:19 PM
ogotaj's Avatar
Default Volvo 940 Turbo and Volvo 940 engines
I found myself in situation when I need to replace engine in my Volvo 940 Turbo from 1995 (just don't ask why). As far as I know its engine coded B230FT is very similar to model B230F used in non-Turbocharged versions of Volvo 940 and 740. Since it's much easier for me to obtain non-Turbocharged model than Turbocharged my question is - ARE ENGINES B230F AND B230FT INTERCHANGEABLE? I really need to replace engine block as well as pistons and possibly a crankshaft but I'm not sure about compatibility. Can I run into some trouble when I use B230F instead B230FT? I'm not sure how oil is supplied to a turbocharger from B230FT and if such hook-up would be possible with B230F.
I will be very thankful for every post on that matter.
Old Dec 28, 2004 | 02:45 AM
Default RE: Volvo 940 Turbo and Volvo 940 engines
Some of the B230F engines had a plug in the block you can remove to install the turbo return line.Some had nothing so using that block would be a pain in the neck.I would also change the head because the cams are diffrent.You may be able to change cams then reshim the lifters.
Old Mar 22, 2008 | 02:57 AM
salvol's Avatar
tubo valves are sodium filled- but will change out into another head. - Actually I think you can take a non-turbo head, read the letter off the back of camshaft, leave it if the same and changeout the valves. A '95 engine has internal oilers. I don't know what year they added that, but after '92 I am reasonably dure.
kevinpi
Jun 15, 2015 05:38 PM
HiRez
Mar 31, 2015 03:26 PM
irollrollie
Mar 30, 2012 11:00 AM
kapka42
Feb 22, 2011 06:37 AM
PANTYEATR
Jan 17, 2008 12:22 AM
