Volvo B230E Oil
Old Feb 27, 2014 | 06:45 AM
danielp's Avatar
Default Volvo B230E Oil
Hi all,
What oil should go in 1989 B230E engine? The manual says 20w50 but on an oil website 15w40.
Thanks,
Dan
Old Feb 27, 2014 | 08:23 AM
I seen nothing in the owners manual about 20w-50, the one I read stated 15w-40.
http://new.volvocars.com/ownersdocs/...0/89740_07.htm
Old Feb 27, 2014 | 08:36 AM
danielp's Avatar
Thanks for the reply. I've got a autodata manual and it's stated in there
Would this be semi synthetic? I've done an oil change and used 10w40 and its made the engine noisy. It could be because I'm running it without the fan attached and it's done 175k.
How fussy are these engines on viscosity?
Thanks,
Dan
Old Feb 27, 2014 | 10:59 AM
we've always used 10W30 on our 240, 740, 940, etc. that 240 has 400K miles now :-O
I generally use mobil 1 synth nowdays, but I used to use castrol gtx dino, not sure its really that big of a deal.
Old Feb 27, 2014 | 11:55 AM
danielp's Avatar
Hey Pierce,
400k? Mines a low miler then.. But I think all isn't well. I was hoping the oil may fix the clatter on over run.
Have a listen Link
What do you think? Little end wear?
Thanks,
Dan
Old Feb 27, 2014 | 12:32 PM
its really hard to diagnose anything from video sound, as there's no reference.
your motor mounts are likely shot from how much the block shifted when you goosed it.
Old Feb 27, 2014 | 12:42 PM
danielp's Avatar
When it's rev'd up and then listen to just at the start of over run. There is 4-5 slight clatter noise. I know it's not the easiest to hear.
I did notice the mounts seem soft... it doesn't idle brilliantly at the moment, I think the ignition timing needs looking at and rocks like a good 'un. How can you tell if the mounts are nackard? The last 240 I had the metal plate detached from the rubber so it was quite obvious
Thanks,
Dan
Old Feb 27, 2014 | 12:54 PM
if the rubber part of the mount is cracking, thats pretty much time to replace. they are rather weak motor mounts.
as far as the clatter goes, I dunno, it could be piston slap. they'll do that for a LONG time before they finally fail, and the best fix is simply to find a new engine out of a wrecker yard or something. it /could/ be a loose or worse too tight valve, those can be shimmed, but if a valve has tightened up, odds are something is wrong, and you'll end up needing a valve job (or a used engine)
Old Feb 27, 2014 | 01:02 PM
danielp's Avatar
Thanks for the advice.
I'm not to worried at the moment, it's not that bad. It's a project car anyway so it would be an excuse to put a more powerful engine in it.
The mounts look very old, grey and perished. It's not split but you can rock the engine easily side to side.
I'll put some new mounts on it
Thanks again,
Dan
dytha99
Aug 20, 2015 07:23 PM
danielp
Feb 12, 2014 08:56 AM
endneu913
Nov 21, 2010 10:53 AM
Boricuaguy18
Jul 22, 2007 06:52 PM
300K 740GLE
Jul 20, 2007 04:42 PM
