Waterpump bolt install on a 240
Old Nov 11, 2024 | 10:16 PM
Bricklover's Avatar
Default Waterpump bolt install on a 240
Hey Folks, I have a weird issue here putting the pump back on my 240. This time (so far) I have no leaks, but the issue I have are the bolts themselves. I put Permatex Thread Sealant with PTFE on the bolts, tightened hand-tight, then tried to torque them. All bolts I can only get to about 15ftlbs with my old needle-style wrench, and past that it feels like they all want to keep on turning. I removed the top bolt, cleaned all the sealant off, and threaded it in and it bit in like a normal bolt. To be on the safe side, I tried another waterpump bolt from a previous job, and it had the same result when putting on sealer. All bolts seemed to look just fine when I installed them, and they were removed just to deal with a leaky gasket while doing the timing belt and cam seal.
I rolled my cam seal somehow when installing nearly a week ago, and parts are coming tomorrow. The car has been stuck taken apart here since Wednesday, and it's my only car.
Old Nov 12, 2024 | 08:29 AM
I'm curious as to why put sealant on those bolts? When the pumps were put on during engine assembly Volvo did not use any sealant or locktight - because it's not needed in that application. (the water pump gasket keeps coolant from being able to get near the threads)
Old Nov 12, 2024 | 10:03 AM
Bricklover's Avatar
Interesting. I actually don’t know where I got that info from, it’s just scribbled into my repair manual off to the side but it’s in my handwriting. Last couple times I’ve done this pump I used it as well.
Should I clean it all off and reinstall the bolts dry, or use maybe a little blue lock tight? That’s in my notes as well.
Old Nov 12, 2024 | 02:48 PM
My shop has probably installed thousands of those b21/23/230 water pumps - When I would install them I would rub the gasket with silicone (rtv) and install the new bolts dry. (I'd rub the top seal with silicone also - made me feel better or perhaps slide in easier.)
Old Nov 12, 2024 | 03:55 PM
jagtoes's Avatar
I would consider getting a bottom tap and tap the holes just to make sure they are clean. Also try to clean out and of the sealant you used as this could be a problem with blind holes.
Pwjeep
Mar 5, 2017 09:22 PM
good1662
Dec 26, 2014 12:05 AM
JimKW
Dec 5, 2011 12:03 PM
AnEskimo
Jun 9, 2010 10:45 AM
TheRev240
Aug 6, 2008 11:02 PM
