what is this?
Old Jan 10, 2014 | 06:26 PM
420DL's Avatar
Default what is this?
i need help identifying the black plug to the right of my oilfilter
i broke the wire going into this plug while changing my alternator, the car runs fine and no check engine or service lights come on, im going to fix it i'd just like to know what it is, thanks!
Old Jan 10, 2014 | 06:38 PM
TIPSP's Avatar
Got Boost?
Low Oil pressure sensor.
Important, but Not too important. Easy fix.
Old Jan 10, 2014 | 10:25 PM
lev's Avatar
lev
If you broke that wire the OIL light should be on...
Old Jan 11, 2014 | 01:44 AM
I think the wire has to be shorted to ground to turn on. if its open, its probably off.
Old Jan 11, 2014 | 02:04 AM
420DL's Avatar
thats what i guessed, yeah no lights are on. ill solder it up tomorrow. thanks yall
Old Jan 11, 2014 | 02:09 AM
dunno if you'll be able to solder to the broken oily terminal end without melting the plastic insulator and gumming up the oil sensor. I'd probably buy a new one, and replace it next time you're changing your oil.
Old Jan 11, 2014 | 02:34 AM
btw, its a $13 part online for the OE part,
Volvo Oil Pressure Switch - TRW / Mera (OEM) 1347003 | FCP Euro
