What is leaking
Old Jun 5, 2017 | 05:21 PM
Cyrilmco's Avatar
Default What is leaking
can someone tell me what this part is that has a leak. It is directly behind oil pan and it has some grate on it with holes
Here is a link to the picture I took, can not get it to show on here.
http://tinypic.com/r/13ynsw7/9
Old Jun 5, 2017 | 05:26 PM
your pic link doesn't work. Try using the Go Advanced button when editing and attaching the image file directly. It would also be helpful to include the model and year of your car.
Old Jun 5, 2017 | 05:31 PM
Cyrilmco's Avatar
I can not find go advanced when I post. so here is the URL ::: http://tinypic.com/r/13ynsw7/9
Sorry for not including model. It is a 1991 Volvo 940 Turbo
Old Jun 5, 2017 | 06:15 PM
jagtoes's Avatar
It is the transmission. The screen is to let oil out when you have a leak either from the transmission seal or the rear engine seal. I suspect you have a plugged PCV system and blew out the rear engine seal. If so you need to pull the transmission to get to the seal.
Old Jun 6, 2017 | 07:21 AM
the tinypic link still doesn't work, but what jagtoes says, from your description, if significant oil is leaking out the grills on the bell housing, thats most likely the engine rear main crankshaft seal.
here's my old 740T...
that oil mess was from the turbo oil return pipe, the seal where it goes into the block was bad (or missing) and the oil that leaked out was blowing all over. it was just a slight drip, maybe one drop each time I parked it.
Old Jun 6, 2017 | 02:47 PM
Cyrilmco's Avatar
Thank guys.
I would say it's a medium leak. In 3 weeks time, I went from having 4.5 gallons of oil down to 1 gallon.
I didn't know what this part was called. But it now sounds like an expensive fix...
Old Jun 6, 2017 | 03:13 PM
4.5 gallons of oil??? ummmm, your engine holds maybe 4.5 quarts, including the filter, and going much below -1 quart (eg, 3.5 quarts) you risk losing oil pressure and killing the whole engine permanently.
Old Jun 6, 2017 | 04:00 PM
jagtoes's Avatar
If you went from 4.5 qts to 1 qt then you have a major leak.
wavewright
Mar 22, 2020 02:10 PM
dutchhillgang
Jul 3, 2006 02:02 PM
tomservo
Nov 4, 2005 09:33 PM
eqnotalent
Oct 19, 2005 08:43 PM
Carbuff
Aug 16, 2005 11:19 PM
