What is this on my Piston Cover?
Old Mar 9, 2010 | 05:10 PM
dman777's Avatar
Default What is this on my Piston Cover?
I've had my volvo 240 dl for about two years now. There always been this weird substance on the edge of my engine...on top of the piston cover I believe...it is some kind of gummy like substance. I'm scared to remove it...scared it might be covering a hole or something. Does anyone know? Is there engine damage and this is some kind of cover up? Should I try to remove it?
Old Mar 9, 2010 | 09:30 PM
docmot's Avatar
If you are reluctant to remove it leave it be. Otherwise with the oil on the cover, cleaning it off will require a new gasket. If the cover is damaged in the corner, you are looking at a replacement or repair.
Old Mar 10, 2010 | 12:35 AM
dman777's Avatar
With that small amount of oil leaking around there(I don't see a change in oil level on the dip stick)... could that eventually do damage to the piston?
Is it hard to replace that cover and gasket?
Old Mar 10, 2010 | 12:44 AM
Typhoon's Avatar
If you are curious, you could take the rocker cover off, thoroughly degrease it and dig that stuff off it.
If you have to re fill a crack or hole, thoroughly degrease the area with paint thinners, abrade the alloy till it is bright with 36 grit sandpaper and have some high temp epoxy already mixed to fill the hole.
Or, you can have the hole welded.
Regards, Andrew.
Old Mar 10, 2010 | 12:56 AM
dman777's Avatar
What I like to do is replace the cover with one that isn't damaged and also put a new gasket on. I'm a amateur(I do oil changes and so far I replaced the oxygen sensor, rear coil springs, and flame trap on my car) so I am wondering if this is a job I would be able to do?
Old Mar 10, 2010 | 06:21 AM
act1292's Avatar
You can clean that off. That is from the firewall cover - I can see up where your ground strap is connected that the black covering on the firewall has come off and melted on your valve cover.
I have seen the same issue on my '90 240.
No big deal
Old Mar 10, 2010 | 07:50 AM
dman777's Avatar
No big deal
Sweet! That makes my day! Thanks
busquetsjose
Penta
29
Oct 18, 2019 06:20 AM
rmosser
Jul 14, 2013 11:47 AM
pj91gsx
Sep 7, 2008 12:39 PM
volvo_s70
Jul 9, 2008 10:54 PM
reg
Mar 5, 2008 03:28 PM
