Where is the Idle Control Valve?
Old Mar 11, 2008 | 03:16 PM
daver80's Avatar
Default Where is the Idle Control Valve?
89 240 DL, she's been idling rough and slow lately, Heard it might be a faulty Idle control valve. Anyone heard of this and where would it be located? How do you increase idle speed? Thanks! Dave
Old Mar 12, 2008 | 07:03 AM
gforce's Avatar
Default RE: Where is the Idle Control Valve?
daver80, It is like my 740 the idle control motor is located under the intake man. towareds the firewall. Motor is about a 1" tube with "T" towards frot of car with 2 hoses attached and wire harness on the fire wall side. I used carb cleaner on mine, make sure you open the spring loaded valve (gently, with small screwdriver) and spray well. I also sprayed plenty in body with valve closed, covered other hole with my hand and shook well. Outcome was a much smother idle. Hope this helps.
Old Mar 12, 2008 | 10:17 AM
funnyguy44444's Avatar
On the 240s (at least on the b21 engines) the idle control valve is located directly on top of the engine block between the engine and the intake manifold. If you open up the hood its basically the highest thing in the engine compartment right in the middle. It is a black or maybe silver cylonder about 3 inches in diameter and 5 inches high with two rubber hoses coming out of either side and a wire with connector directly on top. I would try spraying some carb cleaner in there to clean it out and then some WD40 to lube it all up good.
Old Mar 14, 2008 | 12:13 PM
daver80's Avatar
gforce- heres a photo, is this the thing you are talking about? 2 hoses coming out of front, plug coming out of back. Engine is B230F. Thanks! dave
[IMG]local://upfiles/7102/A05006DF91F241068033FC312825C52A.jpg[/IMG]
Old Mar 14, 2008 | 03:16 PM
gforce's Avatar
That is it Daver80, hope it helps you out to clean it up.
Old Mar 16, 2008 | 04:28 PM
daver80's Avatar
G Force-I cleaned her up, lots of black soot in there, new rotor, oil change, after warm up she seems to stay nice and strong at idle. I'm not gonna celebrate just yet, but... Thanks for your advice, I think I got it! dave
Old Mar 17, 2008 | 05:00 AM
gforce's Avatar
daver80, Awsome hope she keeps running sweet for you.
dnarby
Jan 18, 2014 10:42 PM
Rakam
May 27, 2011 09:03 PM
mygreenbomb
Feb 29, 2008 06:09 PM
mygfslastvolvo
Nov 22, 2005 03:51 PM
