where is my radio?
Old Nov 13, 2007 | 03:24 PM
camofrawg's Avatar
Default where is my radio?
I just bought my first Volvo, a 84 244 DL and love it. I am planning a radio install this weekend, and there is no old radio. The speakers (front and rear) have been removed and where the radio should be, there are pockets, top and bottom. Whereshould the wires be located?
Old Nov 13, 2007 | 05:35 PM
onryboy's Avatar
Default RE: where is my radio?
It should be the top pocket. Dose the bottom pocket have the lighter in it ?
And you can give this link a try but keep in mind it's for the 740 & 760
the 240 link is down.
http://www.installdr.com/InstallDocs...PDF/865001.pdf
Wayne
Old Nov 13, 2007 | 08:31 PM
funnyguy44444's Avatar
Actually the stock radio was mounted in the bottom pocket. So if you're looking for wires they would probably be there. but the previous owner may have put a different system in (it sounds like they probably did since they took everything out) In which case they may have relocated it to the top pocket when they switched it out which is common in these 240s. So I guess the answer is that they could be either place.
Old Nov 15, 2007 | 01:53 PM
camofrawg's Avatar
Thanks guys, I mounted it in the bottom ( the bracket was in the glove box), had to run a power wire because the wires down there were a mess, but it works.
cbgav
Sep 10, 2007 05:25 PM
