Why is gunk / sludge built up in my intake tube? Volvo 1990 740 GL
Old Mar 1, 2015 | 10:01 PM
Question Why is gunk / sludge built up in my intake tube? Volvo 1990 740 GL
I decided to tune up my 745 and part of that service (to me) is to clean out the intake system, throttle body. When I pulled the intake tube, it had a lot of oil/gunk in it. Does anyone know why?
Old Mar 1, 2015 | 10:29 PM
Blue91SL's Avatar
Holy **** dude.
That's pretty bad. Looks like blowby going through the intake. Too much oil/too high pressure maybe?
Old Mar 3, 2015 | 03:10 PM
lev's Avatar
lev
That's oil, not sludge. Normal to have some, may be a little too much in your case. Make sure the PCV (flame trap, separator, nipples, hoses, etc.) are unobstructed. Have you taken compression readings?
Old Mar 3, 2015 | 10:44 PM
No I have not done a compression test. I just fired this car up after sitting for YEARS. There was a lot more than that. I did replace the flame trap and will check it again in a week or so.
Old Mar 4, 2015 | 08:19 AM
Hylton's Avatar
Funny enough, this is very normal in today's GM engines and many simply buy a catch can to keep the oil out of the intake.
Old Mar 4, 2015 | 03:36 PM
said bypass/blowby catch can won't fly in California as they inspect the PVC as part of the biannual smog check.
Old Mar 5, 2015 | 11:12 AM
Mine passed here, 2 years. I also think the exhaust manifold to pipe is loose. Makes that noise.
Old Mar 12, 2015 | 09:10 PM
91-740Turbo's Avatar
Not sure if I remember correctly, did the 745 have a turbo on it? If there is a turbo, it could be leaking oil into the intercooler and then going to the intake.
If no turbo, then check the PCV system.
Old Mar 13, 2015 | 12:40 AM
phew, both the intake and outgo side of the intercooler are on top. I would think the thing would need to be mostly full of oil before it would be sucked into the throttle.
AlanS
Dec 20, 2010 12:20 AM
nmikmik
Oct 20, 2010 10:12 AM
Barracuda
Feb 2, 2010 08:50 PM
smithnr
May 21, 2009 07:03 PM
colgate41
May 1, 2006 04:18 PM
