Will crank but stall out mid crank
Old Nov 25, 2021 | 04:10 PM
Nikko's Avatar
Default Will crank but stall out mid crank
Hi, my 93’ 240 has been sitting and I finally decided to start working on it but can’t get it to start. A month before I redid the timing and got it to run until I let it sit again. I began replacing parts like the motor mounts, deleted the ac, new battery, new spark plugs, new crank gear, and a new timing belt/tensioner And after installing it all it never turned on again. I checked all the fuses, check for spark, gas pump, and starter but still can’t figure it out. I took a video and noticed smoke coming out of a vacuum line and while cranking it would stop and make a slap noise. Any advice would be greatly appreciated 🙏🏼
File Type: mov
urdrwho
Aug 14, 2017 03:27 PM
urdrwho
Aug 6, 2017 02:43 PM
jwandhistools
Aug 11, 2009 09:43 AM
s80 envy
Jan 15, 2008 06:03 PM
