window came off track. HELP.
Old Apr 4, 2010 | 11:16 PM
4cfed's Avatar
Default window came off track. HELP.
hey guys any help would be amazing trying to fix this. car is a 90 740 sedan and its the driverside front window. theres a weird looking bolt that holds it together for the most part and that bolt has become loose.
Old Apr 6, 2010 | 08:50 PM
swiftjustice44's Avatar
The window regulator is mounted to the door with 4 bolts. The regulator mounts to the window with 2 clips and a third clip mounts to the door. The regulator itself works on a scissors principle. So...if there is some sort of wierd looking bolt, I'm thinking that's the pivot for the regulator. You'll need a new one. If you actually buy a new one rather than a j/y unit, you'll get the added benefit of no wind noise at highway speeds. 90's were bad about whistling and even letting rain water crawl up the back edge when the regulator was worn.
Old Apr 9, 2010 | 03:58 PM
4cfed's Avatar
10-4 to that man!
rygar
May 31, 2011 08:13 PM
Feffman
Apr 3, 2011 12:47 PM
cswadner
Feb 12, 2011 06:42 PM
Feffman
Dec 30, 2009 09:10 AM
fishballs15
Aug 26, 2007 12:42 AM
