Wiring
Old Jan 15, 2015 | 04:50 PM
Mr1Guy's Avatar
Default Wiring
I have a 1985 Volvo 245 (wagon) and when I try to turn the key, the ground wire that goes from the battery to the engine block jumps about 2cm, and the car does not start. Does anybody know what the issue could be, and how to fix it?
Old Jan 16, 2015 | 11:19 AM
lev's Avatar
lev
Jumps how? Where? Is it loose? Does engine turn over? Is the battery good?
Old Jan 16, 2015 | 03:21 PM
the ground wire should go from the battery negative terminal to the CHASSIS, then from the chassis to the block, not directly from the battery to the block, unless someone added that.
Old Jan 17, 2015 | 11:47 AM
Mr1Guy's Avatar
The wire is not loose, and the battery we are still unsure if it is okay. And there is also a chassis to engine ground, and the engine to battery ground
Old Jan 17, 2015 | 12:44 PM
again, the ground cable should go battery - -> chassis -> engine. not directly from the battery to the engine.
is the engine moving excessively when you crank it? your motor mounts may well be shot.
Old Jan 17, 2015 | 03:24 PM
Mr1Guy's Avatar
The motor mounts are definitely shot, but should I just move this ground wire to the chassis? Because as is it is battery-->engine-->chassis from what I see
Old Jan 17, 2015 | 07:52 PM
sounds like someone replaced the ground cable at some point, then. where on the engine is it anchored ?
Old Jan 17, 2015 | 10:07 PM
Mr1Guy's Avatar
From the front of the car, it is on the lower part of the block, on the right side near the front (I'm not with the car at the moment, or else I would be able to give a better description)
sdl92
Jun 22, 2013 07:19 PM
Echoe
Aug 26, 2009 12:08 PM
Echoe
Engine & Internal
Aug 20, 2009 12:07 AM
Erock198
Jul 31, 2004 06:16 AM
dust869
May 26, 2004 09:31 PM
