Wiring colour codes and uses on 1987 240gl factory audio system.
Old Aug 5, 2018 | 01:17 AM
Denys's Avatar
Default Wiring colour codes and uses on 1987 240gl factory audio system.
Hi people, I'm replacing the 2 speaker radio wirh the system from my now dead, no compression in 4 cylinders 1999 v70.
So require the actual colour coding and wire allocation of the 240 harness.
Old Aug 5, 2018 | 01:19 AM
Denys's Avatar
Default Thanks in advance.
Taa much.
D
Old Aug 5, 2018 | 02:13 AM
you want this adapter, rather than cutting the wires.
Amazon Amazon
Old Aug 5, 2018 | 07:29 PM
Denys's Avatar
Hi Pierce, thanks, much appreciated.
D
Old Aug 5, 2018 | 08:06 PM
i found my 1987 wiring diagrams... those colors don't match the factory harness connector.
factory harness that plugs into the 2-speaker radio has...
1 green - always on power to antenna
2 yellow-black - accessory/ignition switched power
3 red - control signal to power antenna
4 yellow-white - left (+)
5 grey-yellow - right (+)
6 - n/c
7 white - left (-)
8 grey - right (-)
9 black - ground
Old Aug 13, 2018 | 07:43 AM
Denys's Avatar
Hi Pierce, thanks again. Your info might do the job. This radio was in the lower console position. Would that make a difference to wiring colours. The unit is a factory Volvo radio the harness in the photos I cut from the unit.
Cheers
D
Old Aug 13, 2018 | 02:48 PM
wait, the factory radio had a plug built into the back of the radio, and the harness connector has sockets rather than pins, and plugs directly into the radio.
I think what you have there is an after market harness adapter, similar to the one I linked on Amazon.
Old Aug 14, 2018 | 12:31 AM
again,
6 - n/c
7 white - left (-)
8 grey - right (-)
9 black - ground
I left out the pin diagram.
in your top picture, its
1 2 3
4 5 6
7 8 9
in the middle/bottom pictures, its
7 8 9
4 5 6
1 2 3
so... your wires are...
1 (N/C)
2 blue - accessory/ignition switched power
4 white-blue - left (+)
5 blue-white - right (+)
6 - n/c
7 white - left (-)
8 lt blue - right (-)
9 black - ground
MSGGrunt
Jun 12, 2019 09:18 PM
D3lrayy
Mar 9, 2018 12:31 AM
turbobrick740
Nov 9, 2014 12:31 AM
Kervin
Apr 15, 2010 03:14 PM
ryankayla13
Jun 11, 2007 05:17 PM
