XC70 rims on a 240?
Would these, including the tires, fit on a '92 240 wagon.
2007 - 2001 OEM Volvo XC70 and V70 XC alloy rims with winter tires
XC70 :
215/65R H tiresSize: 16" x 7"
Style:
6 Spoke
Lugs:
Bolt Pattern:
108mm
Offset:
50mm
Condition:
Alloy refinished
Part Number:
307600650
Notes:
Volvo calls this wheel "Cecino".
240:
Size: 14" x 5.5", 5 Lug, 108mm Bolt Pattern
Finish: Painted
Description: Used 5 Spoke Factory Styled Steel Rim
YOU HAVE THE SAME BOLT PATTERN OF 108MM but your 240 has this small pin thing on the your rotor bolt face? "that you can take off to fit the XC70's...? tires might be the problem....! Can you fit before buying?
Style:
6 Spoke
Lugs:
Bolt Pattern:
108mm
Offset:
50mm
Condition:
Alloy refinished
Part Number:
307600650
Notes:
240:
Finish: Painted
You definitely need adapters because of the off set and most likely smaller tires. Check out IPD.
25mm H&R TRAX+ Wheel Spacers 240 740 760 780 940 960
