130 degrees ? Head bolts
Old Dec 16, 2010 | 09:32 AM
pdieni's Avatar
Default 130 degrees ? Head bolts
When tightening the last round after going through the 15 ft #s then 44 it says to go 130 degrees ? I take that as the ratchet being a second hand on a clock and actually pulling it 130 degrees so If it were a second hand on a clock it would be about 20 after ?
Old Dec 16, 2010 | 01:19 PM
dan550i's Avatar
It is an arc, if the hand on the clock was at 12 - 3 would be 90 degrees,
6 would be 180 degrees.
So you will need to be starting at 12 and pull to just past 4 on a clock face.
I used a piece of cardboard for the sweep and taped it down so it would not move.
DanR
plumsmooth
Feb 5, 2015 06:03 PM
PsychoBeano
Oct 29, 2014 06:12 PM
meero80
Feb 2, 2013 05:53 PM
El Bucho
Dec 3, 2009 10:01 PM
