1994 volvo 960 tranny problems
Old Feb 6, 2013 | 05:39 PM
Johnny Hamm's Avatar
Default 1994 volvo 960 tranny problems
HI, I have a 1994 volvo 960 wagon. An arrow shaped light indicator flashes on the dash and the three w s e indicator lights next to the shifter cycle through flashing sequence. I need someone on the sanfrancisco peninsula with a block reader I can plug in to diagnose my problem. Help. johnny hamm @ volvo forums
Old Feb 7, 2013 | 09:38 AM
MarkB1982's Avatar
I think I can tell you what the problem is... I had the EXACT same symptoms occur with my 1994 960 wagon, the arrow, the flashing WSE etc. Turns out that there was a very slow coolant leak that flooded a switch which told the computer which gear to be in. I ended up having to replace the switch which was like $700.
That was about a year ago and now the coolant leak has gotten worse and the problem is starting again!
If anyone can help me figure out the coolant leak I would be appreciative. It only seems to leak out when the car is off, doesn't seem to matter if the tank is pressurized. It does seem to hold some coolant , whenever I check the tank, it is empty but has coolant in the hose.
I smell coolant cooking off when I park the car, no obvious drip to be seen though.
apoulos
Apr 15, 2022 05:08 PM
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
zortiz1515
Jul 13, 2011 12:49 AM
Volvo960Wagons
Jul 1, 2008 01:19 PM
mikkowus
May 20, 2007 05:48 PM
