1996 960 fuel pump replacement
Old May 22, 2009 | 08:21 AM
Systek's Avatar
Default 1996 960 fuel pump replacement
I found a 960 in great shape but the fuel pump seems to be out. Either that and/or the fuel pump relay. I tried searching for information on where these components are located at and how to replace them but have not found anything. Can someone point me in the right direction.
Here is the ad to the car and i already spoke to the seller. He is MOTIVATED to get it out of the driveway!
http://houston.craigslist.org/cto/1139762317.html
Let me know what ya'll think!
Old May 22, 2009 | 09:26 PM
First thing I would try is to go into the trunk on the drivers side and get behind the trunk panel.
There is a plug there that goes to the fuel pump. The plug has a pink wire. Check the wires for power when cranking. If you have power when cranking and loose it when you stop cranking then the pump must be bad.
Old May 27, 2009 | 10:24 AM
Systek's Avatar
cool, thanks for the advice!
spidersilva
Aug 17, 2011 07:23 PM
HunnyBunny
Dec 14, 2010 07:18 PM
coleman
Aug 8, 2010 04:03 PM
jruyle
Nov 21, 2008 04:12 PM
