1998 V90 Transmission flush
Old Apr 24, 2010 | 03:20 PM
322hunter's Avatar
Default 1998 V90 Transmission flush
Just purchased a 1998 V90 with 66,000 miles-From Hawaii hence the low miles
I have always had v70 and been able to change the Transmission Fluids via the
IPD flush kit. But this V90 has no transmission Dip Stick and it doesn't look like it has any line into the radiator. I called IPD and Ken said he wasn't sure as they don't have a flush kit for the V90. Any help/
Old Apr 25, 2010 | 05:04 PM
dan550i's Avatar
IPD never had much for the 960's, there should be trans lines near the battery. If not, maybe a separate cooler was fitted?
The dip stick is below the brake booster, about an arms length down, has a yellow cap but no loop to pull it up. It will have a 3/8" square hole in it.
I flush my trans all of the time, using the trans cooler lines to fill a marked container. I just did a post here a few weeks ago explaining the procedure.
DanR '94 964 350,000 miles (116,000 on the new engine)
martin calva
Apr 15, 2015 04:59 PM
patrm
2001-2013 model year V70
23
Mar 5, 2014 08:43 PM
DinWilm
Feb 21, 2014 03:03 AM
shop2
Nov 1, 2011 08:56 AM
Glenn B
Feb 19, 2008 04:57 PM
