760 t has no power, i think i want to buy it.
Old Oct 15, 2008 | 01:03 AM
  #41
TIPSP's Avatar
Got Boost?
Default RE: 760 t has no power, i think i want to buy it.
Here is the link for the 16v head conversion.
http://forums.turbobricks.com/showthread.php?t=31900
Old Oct 15, 2008 | 12:38 PM
  #42
chicksdigmiatas's Avatar
That looks like way more crap than i want to do on this car. It was way easier on a 240. Thanks for the link though.
Old Oct 15, 2008 | 01:07 PM
  #43
http://i277.photobucket.com/albums/k.../cranktool.gif
That tool? Can i not use it? I am tight on money right now, and wouldn't normally skimp on the right tool. But if there is a trick to save me some money, that would be awesome. If not, it looks like ill just have to wait.
PS it is an auto, so sticking it in gear wont work.
Old Oct 15, 2008 | 01:11 PM
  #44
You really should have that unless you have a really stong 3/8 impact gun or a short 1/2 drive.
Or is all else really fails pull the Radiator then use your 1/2 gun.
Old Oct 15, 2008 | 01:12 PM
  #45
Well i haven't priced it yet, i guess the volvo dealer? Or what? If so, what am i looking at money wise?
Old Oct 15, 2008 | 01:15 PM
  #46
Not sure about the price but I think pretty expensive.
I never use the tool except on turbo cars that my 1/2 gun won't fit on.
Which in 3 years I think I have only used 2 to 3 times.
Old Oct 15, 2008 | 01:26 PM
  #47
Well ill just put the gun to it then, thanks. It prob needs coolant flush too huh?
Old Oct 15, 2008 | 01:35 PM
  #48
It could very well need it.
Old Oct 15, 2008 | 02:37 PM
  #49
Well i changed the oil, i woulda flushed it allready if i wasn't broke, i will just look at it as an opportunity in disguise. I will do trans flu and filter too when i get the chance. Your supposed to do that like every 5 or 6 oil changes. No one ever does it. The miata is expensive, royal purple is 15 a quart at work now. It sucks. Atleast it only holds 2 quarts though. I am engineering a tool. I will let you know. Cya.
Old Oct 15, 2008 | 02:46 PM
  #50
The 740's were every 20K on the trans service thats drain and refill.
Old Oct 15, 2008 | 03:38 PM
  #51
When i took the crank pulley off, it was still wrong. So dont worry, the crank pulley was correct. It looks like the cam was advanced 2 teeth. So i am setting it back right now. Just confirming though, that was the correct timing mark for the cam i had circled in the small circle right, ill repost it so you dont have to look.
http://i277.photobucket.com/albums/k...e/SNC11882.jpg
Where the cam was lined up.
http://i277.photobucket.com/albums/k...e/SNC11885.jpg
The crank lined up, it is still the way as it was in the pic above.
http://i277.photobucket.com/albums/k...e/SNC11886.jpg
The ghetto fab east tennessee redneck crank pulley holding tool. I made it out of 1/8 inch steel.
Let me know what you think.
Old Oct 15, 2008 | 04:11 PM
  #52
http://i277.photobucket.com/albums/k...e/SNC11891.jpg
http://i277.photobucket.com/albums/k...e/SNC11893.jpg
Thats where all the stuff is lined up. Im almost certain it is correct. I turned it over with a ratchet and there was no interference. So i guess no worse than when i started right?
Old Oct 15, 2008 | 06:02 PM
  #53
Looks like you got it as long as the crank lines up as well. The outside washer that was on there the groove should line up with the mark on the block.
If all that is good then you should be good to go.
Old Oct 15, 2008 | 06:36 PM
  #54
Man i think i put on the wires wrong i did it like alldata said so.
1,3,4,2 with cyl one starting at the 3rd post.
so this is how my back dist cap is from left to right. 4,2,1,3 is that right?
Old Oct 15, 2008 | 06:42 PM
  #55
Oh yeah, which one is the pos wire on the coil, the red/wite right?
Edit- I meant blue, its hooked up right. I think the firing order is off. I have blue on pos and red white on neg.
Old Oct 15, 2008 | 07:15 PM
  #56
Yes the firing order is 1,3,4,2
I believe cyl 1 is the left most post in the Dist cap.
Sorry just got used to putting the wires on the cap before installing them.
Old Oct 15, 2008 | 07:34 PM
  #57
4,3,1,2 from left to right has it moving but there is a miss.
Edit- we found a broken cylinder 2 wire. So here is my assumption. Alldata was right in a sense. It starts at the 3rd from the left, and is numbered clockwise looking at it from the back. So im an idiot. Now that it has heated up, it still doesn't start. Now thats gay. It has more power on 3 cylinders than it did on 4 before. So whats up with the no start condition.
Old Oct 15, 2008 | 08:01 PM
  #58
ECT?
Old Oct 15, 2008 | 08:53 PM
  #59
My cheater book says
ECT
Resistance at:
-10C(14F)..................Ohm 8 260-10 560
+20C(68F)..................Ohm 2 280-2 720
+80C(176F)................Ohm 290-364
Hope that helps to test the ECT
Old Oct 15, 2008 | 10:37 PM
  #60
Thanks your a pimp, ill check that tomorrow.
